Front Brake, Rear Brake, Clutch/Decomp, and Throttle cables. Taken from a 1979 MP-19 with 625 miles on the clock. The rear brake cable threaded barrel adjuster is broken off but you might be able to make it work with another slotted adjuster. The throttle cable has a little wear near the bottom (carb end) on the outer sheathing but it still works OK. The clutch/decomp cable does not have the adjuster on it.
I replaced all these cables with NOS parts even though these original bits really weren't that bad. $20 and I'll toss 'em in USPS for you.
