WTB Puch ZA50 center stand springs
I believe they are shorter than the 115mm E50 variety but I don't know the exact length. Lemme know whatcha got, need a few
Re: WTB Puch ZA50 center stand springs
They are all the exact same size....
False.
I can take a look tonight
ya they different sizes. free bump
I have some NOS springs. And according to every dealer parts book I have the spring was the same. Part number 128.2410. The difference is whether the moped has the correct stand on it. And I believe aftermarket stands didn't have the spring nub in the exact location.
Correct. The springs are all the same size. You have to have the correct centerstand and the bracket shim in place. If the shim is missing, the stand in the retracted position will sit too high and your spring may also appear loose. I have many, many springs and they are all the same size.
Ditto
> size.
Bracket shim is that metal flange that bolts onto the back side of the bracket?
Yes. The shim was really only used with longer center stands as found on Magnums. If your center stand or holder has wear, this will also affect the spring and how loose it appears
i learned a thing
> Mike Boyd Wrote:
> i learned a thing
yeah me too
