WTB stock D square bing carb
Looking for a square D carb for my sachs
Re: WTB stock D square bing carb
I think I have one. May not be very clean. I’ll try to remember to check when I get home tonight.
I appreciate it!
I must have got rid of it, it wasn’t in my box of parts. :(
Jimmy Cincinnati /
I have one minus the cap & slide. I think its a 12mm.
Michael Domanski /
I've got this
> Michael Domanski Wrote:
> I've got this
Does it have a needle in it? I need one that doesn't have a needle
Richard Eberline /
85/12/104a is for a Sachs 505D
This is looking like it’s harder to track down than I thought haha
Alex, what happened to the one that came on the bike when I sold it to you?
> you?
It’s not a D carb, someone had swapped it with an A carb, which slows the bike down a lot so I’m just looking to do the easiest fix. I bought the MLM intake and vm20 but it doesn’t fit without some modifications. I’m just looking for the easiest thing to do and Andy Scouten said the stock D carbs rip with that airsal set up
Jimmy Cincinnati /
What number are you looking for on the carb? Like i said, i have a carb without the cap / slide that is a 12mm.
> without the cap / slide that is a 12 mm
I just need to make sure it doesn’t have a needle in it, I’m kinda new to sachs so I’m not for sure, I just know it’s the stock carbs that came on the 505/1D.
85/12/104 is the stock D carb which came stock with a 58 jet. I believe the carb had a 68 jet in it when I sold it.
Anyway good luck. Hope you get it ripping!
It’s running great, it just won’t go past 30 because of the carb haha it’s an A carb on there now not a D. That’s the only thing holding me back
Pretty ugly but I found it. Your for shipping if you want it. Maybe I’ll even wipe it off!
Messaged you on IG
