FS: DERBI START5 VARIANT
Ryan N. /
Rebuilt bottom end
50cc gilardoni kit
Lomat intake with stage6 (vforce) 8 petal reeds
Polini variator
Brand new NOS belt
Parmakit cdi box
Mikuni vm18 carburetor (with cable choke conversion)
NOS (a few days use) giannelli hiboy exhaust
2.5k clutch springs
Lusito controls
New cables
New motor mount bushings
New brake shoes front and rear
Newer tires and tubes (from a year ago)
New sealed wheel bearings front and rear
The kinda bad:
One of the mounting holes on the Kickstart cover is fucked up and can't be used. Seat has a tear in it covered with black duct tape. Side kickstand is reverse and welded to the subframe (works great!). Tail light lens is cracked in half but still present. Headlight fairing was cracked but I plastic welded it from the rear, you can hardly tell.
I have stock start5 pegs for it but they need to be modified a bit to fit this frame (no welding necessary just elongating the hole for the motor mount bolt).
Bike runs well.
I have a Vermont registration in my name that I can sign over to you so you can title it in your state.
I'm asking $1600.
Located in NEW ORLEANS. Will not ship so don't ask. I will however work with a uship situation. (edited)
