Completely rebuilt 70cc E50
Cases cleaned with new full circle roller crank, new bearings, seals and gaskets, studs drilled and tapped for m7 studs because original were stripped, new 45mm airsal piston port kit, 45mm hi comp head, BR8HS plug, new cheapo CDI that was bolted on another engine and started once then removed to go back to points. A mixture of new hammer and jammer parts with kevlar lined shoes never ran. $550 shipped out right or $450 shipped if you send me another bottom end with no stripped holes. If holes are stripped the exchange will be less depending on which holes are stripped.
Re: Completely rebuilt 70cc E50
Pics
More pics
The clutch will come with three different sets of springs. Blue, yellow and red. All you need is your carb, intake, pipe, oil in tranny and premix! Can't get no better than that! Huh? Huh? HUH?!?
Clutch parts are just for reference showing what I used to assemble it. No you don't get all the extra parts......
Or 450 shipped out right or $350 shipped if you send me another bottom end and I remove the top end. So you would get bottom end only.
Stephen Roberts /
is this still available
Yes it is
SOLD!
