Completely rebuilt 70cc E50
Stephen Simmons /
Cases cleaned with new full circle roller crank, new bearings, seals and gaskets, studs drilled and tapped for m7 studs because original were stripped, new 45mm airsal piston port kit, 45mm hi comp head, BR8HS plug, new cheapo CDI that was bolted on another engine and started once then removed to go back to points. A mixture of new hammer and jammer parts with kevlar lined shoes never ran. $550 shipped out right or $450 shipped if you send me another bottom end with no stripped holes. If holes are stripped the exchange will be less depending on which holes are stripped.
