Needed: Brake spring for Puch snowflake rear rim
Mostly what I need. Could use a brake swingarm the spring snugs against too, but mostly I need the spring.
Re: Needed: Brake spring for Puch snowflake rear rim
Probably Fred /
Though not easy to install/use but you could use a regular rim spring instead of the specialized snowflake rims spring
A. J. Souza /
Again, thanks to the ever present and full of info Ken Roff.
So...risking stupidity (mine): What is a "regular rim spring"? Never heard term before.
Probably Fred /
> heard term before.
The spring is different on snowflake mags
This is a regular spring though it’s a little stiffer because it’s a aftermarket one (I prefer oem)
https://www.treatland.tv/leleu-rear-brake-plate-return-spring-p/moped-brake-return-spring.htm
EH 📣FCC of the QCB /
I think I have one sitting on my shop floor. I
A. J. Souza /
Ah..okay Ken, got it. Just a regular Leleu spring, nipped and tucked to form. Think I might have one of those outside.
Baron: " ...sitting on my floor." But do you know where? Let me know, if you don't need to tear the place apart to locate. I don't need it yesterday...or next week.
Thanks to each of you, regardless.
I think this may work. Let me know
