Hand made tig welded puch magnum/freespirit flat port pipe!
Re: Hand made tig welded puch magnum/freespirit flat port pipe!
Dirty30 Dillon /
Outside of ebay, what are you realistically looking to get for the pipe?
150-200
I havent got all the processes ironed out so it still takes me quite a while to make one of thies so my end goal is 150 but as of right now i need 200
Have a few on hand
> need 200
Shipped?
200$ shipped.
Mounting point
How Would these perform on a stock magnum cylinder?
Would you make one for a angle port?
wow looks great guys!
They look GREAT!
Thanks Graham (edited)
The stinger id is 17mm so it is more suited for 70ccs.
If your ported and don't have a stock intake/carb it should rip but low end will be weaker.
I plan to make an angle port version but i haven't worked it out yet.
Whats the ID of the header? I run a treats Gigantor pipe on my 74 Eurokit, but the header ID is only 24mm.
Specs on the header tube are 25.2mm id but after welding its between 24-25.
The problem is puch exhaust studs are narrow 1 1/8in tube max or you wont be able to get nuts on it.
These look great! How do they perform?
The pipe is designed for great mids and greater highs.
any chance you'll be making a flat reed one?
Looks fantastic
I want to but puch, hobbit, v1, mb5, ns50, garelli, moby and califfo are the bikes i have to mock up to at the moment.
Oooohhh one ns50 please.
Any chance you would post a few dimensions? (edited)
Header is 25mm id belly is 102mm od stinger is 17mm id but i can change anything you'd like.
What tool do you use for cone rolling?
This is great. How do they do on pedal clearance / center stand fit?
I use a slip roller to make the cones.
They clear the center stand and pedals on magnum/free sprirt other wise your gona need a pedal extender and depending the rest of your set up might have to widen the slot on the mount.
Looks awesome dude
Garelli noi?
Yah noi
> Ryan Go Wrote:
> Yah noi
Sent you a PM Sir.
