Looking for a triple tree from a 80 Tomos bullet
Kristoffer Johnson /
Does anyone have a triple tree from a 1980 TOMOS bullet?
Thanks for reading
Re: Looking for a triple tree from a 80 Tomos bullet
♣Slew Foot♣ /
The beefier streetmate forks will fit if you didn't know.
Awesome. That open the search a bit. Thanks
pretty much any tomos forks will go on any tomos, the frames didn't change.
you will have to have the right triple tree to match the right forks, might want to post a pic to get the right ones. you should have the ones that have the little tabs welded on the fork tubes that bolt onto the lower triple
This is what I am after.
I’m getting my broken one welded but if there was a fork upgrade that fit my existing wheels I’d do it.
oh yeah you want a full set of A35 regular side down forks, everything will swap over and much nicer forks.
should be cheap, people are always getting rid of them to upgrade.
better yet find a55 era forks that are much much better.
♣Slew Foot♣ /
That and the newer fork sets have a retaining bearing ring not cone and balls
