FS/FT: Moparts Racing Hybrid Vario conversion for vespa
Converts single speed vespa transmission to vario and allows the use of a minarelli scooter clutch.
https://www.mopartswebshop.com/moparts-racing-hybrid-variomatic-shaft.html
Also included: Minarelli clutch with with polini bell.
I bought the first version of this a few years ago and ended up abandoning the project that this was meant for.
^I will sell both for $150 shipped.
Will consider trading/partial trade for:
One of these better than stock vespa clutch bells:
https://www.treatland.tv/vespa-piaggio-c40-STEEL-racing-variated-clutch-bel-p/cnc-vespa-bell-steel-v2.htm
https://www.treatland.tv/vespa-piaggio-manganese-steel-alloy-racing-clutch-p/magnese-steel-clutch-bell.htm
Or a vespa polini vario, a minarelli v1 or morini m1 phbg intake for use with clamp on carbs, a nice morini pipe (for a kitted m101).
Re: FS/FT: Moparts Racing Hybrid Vario conversion for vespa
pm'ed
Dirty30 Dillon /
pm'ed
hit me up
Dirty30 Dillon /
double post (edited)
SOLD
Brad Cat (LSLB) /
Who ever bought this sell it to me
Dirty30 Dillon /
Two steps behind me, my dude
Here’s the how to for converting the ss transmission to a scooter variator.
https://vespa-ciao.nl/how-tos/overbrenging-how-tos/Fox-koppeling-monteren-op-vespa-ciao/
There is also someone making a kit to run a scooter clutch on the stock variated transmission. Here is a photo of it from another thread.
Dirty30 Dillon /
The modded scooter variators for stock trans are very expensivo, but very cool
> very cool
I can imagine, it was some random Vespa tech I’ve come across.
Dirty30 Dillon /
> > very cool
I'm saving those tech docs for future use. I have a feeling I will need to repro the hybrid shaft I currently have.
I did the swap on a kinetic single speed transmission, I’ve run into a few issues using it vs the Vespa trans. The oil seal for sure the scooter shaft was a larger od I had to open that up on the kinetic case. Then I went to put it in a Vespa spoked wheel and the case was rubbing on the spokes so I turned off the material that was rubbing, It fit in a mag wheel fine before machining. I’m hoping to test is out in the next month or so, it’s going on a grande I’m building.
