Parting out two, Honda NC50 Express Mopeds, between the two of them there is 90% of moped. Will sell one complete if local, or will ship in pieces. Both are yellow. I am located out of the Detroit metro.
Many parts if something is not listed please let me know what you are looking for.
Currently loose parts and prices, Minimum order $20 but will discount on multiple items on order.
Headlight Ring - One tab broke and without part to fix - $15
Headlight Ring - Ring Broke, includes light and fixtures, one tab broke and with part to fix -$15
Headlight Bucket - Broke see pictures, includes speedo - $20
Speedo - Good, Include broken bucket - $20
Ignition Switch - No key - $10
Horn - Clean, can test - $15
Fenders - Two Fronts, Two Rear, will include supports - $30 for undamaged set, $15 for cracked set
Seats - Covers in bad condition, Foam useable - $30 for seat with better cover and wing nut on plastic line. $15 for other.
Foot Peg Trim Covers - 2 set, both good condition - $30 per pair
Main Wiring Harness - Good condition - $20
Right Side Controls - Wiring good, aluminum not pitted - $40
Left Side Control - Wiring good, aluminum not pitted - $40
Cables - Please ask more if one if need there are each in different shape.
Cylinder Head - $10
Air Filter Housing - Missing the "cage", see pictures for part included - $30
Air Filter Mount - Good - $10
Rear Shock - Functional - $20
Gas Tank - x2 one if better than other - $40
Gas Cap - x2 - $10
Muffler - Ok condition usable - $50
Bare Frame - This frame is rustier that the mostly complete frame but still usable, handle bar include if pick up - $100
Transmission - Has been split open but use bolted back together cover good condition - $200 or will part out sub-components
Lower end of engine - engine is unable as the head bolt holes are striped so I can part out the sub-component on the crank.
Rear Wheel - Includes brake assy, currently on transmission- $80
Front Wheel - Includes brake assy, Ok, some rust pitting in the drum but I believe it is salvable - $60
Shipping is not included in any price. If it can, I will ship via USPS flat rate shipping which is from $7 - $17 depending on size. Shipping cost is per order. Flat rate units will include packaging material so items are not damaged in shipping. If a large item can't ship flat rate, packaging material are at the cost of the buyer, cost to ship to your location can be quoted. I am willing to ship a frame or other large item if disassemble to be flat and under 70lbs.
