82 Urban Express .. who needs parts.
First come
First served
Everything gots to go..
Liquidation!
No part left behind!!
Re: 82 Urban Express .. who needs parts.
Captain Janeway /
Front brake cable to 94611
Rear wheel in good shape?
petcock plz
Kevin Bishop /
CDI flywheel and stator
Jyro Smalls /
carburetor
Matthew Hardgrove /
OMFG, YES! I need bolts! Had an asshole steal my toolbox, and a lot of little bits were in there!
I will buy every single bolt and nut that attaches to the motor, all of them! Need the bolts that attach the motor the the frame and kickstand too!
Need a wiring harness (only if it’s uncut) and a speedo cable.
I’m sure I’ll need more parts, but nuts and bolts are what I most need!
Front brake hub to reno
Battery box? To 47172 is the bracket for air box and rear fender there also and the washer behind the kickstart gear with the spring hit me up!
I need quite a few parts, I need the air box and everything leading up to the carborator, muffler shroud, headlight bulb, battery box, rear turn signals and the mounting bracket for them, and the Amber covers off of the front turn signals, I need the stator too but looks like someone might have already got that to 48615 central Michigan
I need quite a few parts, I need the air box and everything leading up to the carborator, muffler shroud, headlight bulb, battery box, rear turn signals and the mounting bracket for them, and the Amber covers off of the front turn signals, I need the stator too but looks like someone might have already got that to 48615 central Michigan very interested
I need the front turn signals and brackets
Downhill Harvey (OFMC) /
Speedo mounting bracket and speedo housing. Rubber front fork boots, if good.
I need complete front forks to 40509 if still available!
PM sent
Captain Janeway /
All the hardware for Kickstarter ESPECIALLY the bushings that go to the case, that sleeved washer behind the spindle against the case and the thrush washer against the case behind the spring. Also if you can pop it, the gear on the crankshaft. I have one with chipped teeth to 94611
I'll be at Creatures rally if you're going (edited)
gas tank>
Do you still have the gas tank for sale?
