Looking for 1984 Yamaha MJ50 Towny speedometer
Hi, I am looking for the actual speedometer and possibly the clear plastic that covers it.
I have a new speedometer gear and cable installed, But something is messed up with the gears in the speedometer and it just spins in circles at the same rate as the front wheel.
The black plastic case, the 4 light bulbs, and the ignition all work well.
The clear plastic on top is shattered.
I am looking to spend around $20USD plus shipping.
There is one on ebay now with broken clear plastic on it for $26 plus shipping.
So if you have one with good side and top plastic I might be willing to pay a little more.
Please email me if you have one thanks.
arilumbroso@gmail.com
Re: Looking for 1984 Yamaha MJ50 Towny speedometer
William Johnson /
same as a qt50
Aaron Lumbroso /
Almost, the Towny has 4 lights (high beam, turn signal, low oil, and start position) while most of the qt50's had 3 lights (no start light).
Aaron Lumbroso /
If you have a qt50 speedometer I would not mind the missing light,
