FS: Vespa parts Make me an offer
Dan (high idle) Conway /
-I've got a bunch of old (but clean) 12/10 SHA parts
-Stock Jug in good shape
-Bravo Bottom end with crank and piston (pm me for details)
-flywheel
-polini blue Spring
-stock variator
-couple bent up pedal cranks and a freewheel
Will make a deal on multiple parts
Buyer pays shipping
Re: FS: Vespa parts Make me an offer
grim ripper /
how many pins is the crank in the bottom end?
Jimmy Cauchon /
I see oiler holes in the com rod. Wouldn't that make it a 12mm pin?
...(or 12 pins )
due to the dual oiler holes, it would lead me to believe it's 12 like James said
Fuck, its not that hard to measure
I mean it's not even that hard to see the difference between 10 and 12
I measured the wrist pin hole and it is a 10mm wrist pin, all I can tell you is it came in the case.
I would be interested int he original jug and the fly wheel. i would like to try to mod them you know? what do you think?
bump
Still have spring, Jug, Flywheel and variator
Still have flywheel and Cylinder
C'mon 40 bucks takes both jug and flywheel shipped USPS priority
