FS Tomos a35 carbs,intakes,heads,cylinders pics inside.
Tomos a35 parts for sale or trade make me a offer? must pay shipping
1. Sha 15mm carb complete with shim and gasket for intake. bought new still looks new
2. 14mm carb clone with air filter, new shim and gasket for intake. Bowl is to tall. Need shorter bowl. bought new still looks like it. Air filter was shaved alittle to make it fit on my bike. Took a little metal off the corner of it.
3. 15mm intake oil injection hole sealed with epoxy and bolt.
4. 20 different 5mm jets all are different sizes.
5. New 38mm std piston with rings still in plastic.
6.2 Oem tomos 38mm heads black says tomos on them. Used they look great.
7. Oem tomos 38mm steel cylinders jugs one has studs in the exhaust the other doesn't. They feel smooth on the cylinder walls I would run them.
8.50cc dmp cylinder with piston this was on my bike before I upgraded to 70cc looks good.
9. 2 tomos stock pipes one is grey the other black.
10. I have 2 14.12 sha carbs both are complete and used no intake gaskets for the shims in back.
11. 3 12mm intakes two are straight with oil holes one is the side intake with no oil hole.
12. 70cc cylinder. the port holes are messed up dint use this cylinder maybe u can?
13. 50cc cylinder used. I try to clean it up with a ball hone made for the nikasil coating.
14. 50cc hi compression head used needs gasket to run with it or mill it yourself will give u a extra one u if like.
Re: FS Tomos a35 carbs,intakes,heads,cylinders pics inside.
more pics
more pics 2
more pics 3
more pics 3 (edited)
more pics ...... (edited)
random parts sold, 5mm jets in the case sold
How much for the jets?
how much for the 15 intake
Erwin Schrodinger /
How much for a stock A35 head?
Andrew Squiggman /
14 items listed.
not one price.
