Race ported stock hobbit top end
Want a crazy hobbit stock top end for the races?
I went hog wild with this jug.
It's too much for me. With a nice high clutch stall,
It is crazy powerful. Lift front wheel powerful.
Aux ports, decked 2.5mm, finger ports, bunch of piston mods.
Everything chamfered, I can help with carb settings as well as its a bit tricky to tune.
$250 shipped.
Re: Race ported stock hobbit top end
Oh, comes with the aluminum spacer too.
Can throw in a custom cut puch head with a great squish band for a bit extra.
Pm me I want it man!
You sell this? How wide did you cut your squish band (mm)?
Still for sale. Races coming soon.
Wanna dominate in the stock class?
This bore is for you!
$200 shipped
Jbot what carb would you recommend for this?
ill trade you for that ported a55 cyl got from you??
Haha, nope.
That one runs ok, but as you saw the aux port didn't work out.
Still ran kick ass.
I ran a 19 on it, but stock classes are limited in carb usually.
You need a multi circuit carb tho.
It's a bit touchy to tune.
With a 19 phbg I was running a real lean w8 needle and it got to 50 with a notched variator and stock camino pulley in less than a block.
Oh, and if you run this with starter shoes it's a huge drag.
Pull start or drill start is a must.
> huge drag.
one way bearing
Or mod your bell for a one way bearing. I'm down to try that
Overpriced Parts /
> to try that
Can you post pictures of it
simple,
this bearing
http://www.vxb.com/HF1616-One-Way-Needle-Bearing-Clutch-16X22X16-p/kit7824.htm
This rod
http://www.vxb.com/16mm-Shaft-30-Hardened-Rod-Linear-Motion-p/kit1006.htm
drill/bore the rod out, replace the spacer that goes on the crank with that instead and swap out the bearing.
Michael Goldschmidt /
Are you selling elements of the bottom end, too?
Bump.
Want to throw a massive kit on my bike that has this 50cc top end.
I really want this top end to go to someone to race with it.
$125
THATS A 50% DISCOUNT! OMG HE MUST BE CRAZY! NO FOLKS WE JUST WANT THIS LIL SCREAMER TO RIP AROUND A TRACK.....WITH YOU!!! CALL TODAY
