where to buy: za50 output shaft caged bearing
the one that is pressed in the case (stator side), 13mmx17.5mmx15mm, the end of the output shaft rests here
puch part #900.6888 was made by Torrington which was bought and split 50/50 by koyo and timken
after talking to my bearing distributor they assumed that timken would have a replacement but I've had no luck, any help appreciated
Re: where to buy: za50 output shaft caged bearing
Here is what I got from the July 1978 Puch parts manual:
Diagram Reference # 19 is Puch part #900-6885 NOT 900-6888
Exact dimensions according to Puch are 12.7mm X 17.46mm X 15.88mm
Described as a needle bearing (Torrington)
Harley-Davidson used very similar bearings in the twin cam motors. (edited)
If you can't find the bearing by itself then this would be a option especially if you need any of the others in the set.
[url=http://www.jmpbparts.com/puch/engine-parts/various-engine/lagerset-
puch-za50-inclusief-shiftaslagers.html]ZA50 bearing set here[/url]
Also I noticed the bearings in that kit are NOT true Torrington bearings as seen in this pic, so go back to the bearing store and search for a INA in the appropriate size. Make sure they're rated for the rpm you plan to spin it.
(edited)
Complete bearing set here overseas
Look closely, notice that is does not have the true Torrington bearings in the set as pictured above^^^
river 2strokes /
its for the output shaft so it won't be spinning up like a crank bearing, but thanks for the info need to order one asap
Hey I noticed that bearing set has every bearing BUT the one you need. See if you can get an INA type bearing in the dimensions I posted above. Yes the output shaft won't spin at crank speed but every bearing has its limits. You just need to be cautious outsourcing when you can't find original. (edited)
> manual:
> 900-6888
> 17.46mm X 15.88mm
> twin cam motors.
Hey just looked in the Maxi part manual and this is what it said:
900.6888 Needle bearing 12.7mm X 17.46mm X 14.88mm torrington replacement for 900.6885
So you have the CORRECT part number after all. The old number was superseded to the one you mentioned above^^
river 2strokes /
..back to OP, anyone know where to buy them?
Double Trouble Dan /
I have some at DMW if you want me to ship.
Also; is yours bad? If not, no need to replace.
river 2strokes /
pming you on fbook to order
I accidentally popped the closed end off and 30 needles fell onto my workbench
did not think it would be that difficult to find glad to hear you have one!
river 2strokes /
found! thanks alex/DMW!
Stator /ignition side of the case doesn't have a roller it has a ball.trans/clutch side does have a roller I think its something like a b-810 I just replaced mine.
river 2strokes /
lol ok.
