Wtb puch 70cc kit new or used
70cc treats kit preferably but what do you have?
Re: Wtb puch 70cc kit new or used
Probably Fred /
This blows away a treats piston port kit.
Ya the angle is more like magnum so you got to bend the exhaust header somewhat but I had no problem fitting a estroil or boss to these kits.
Any pipe except a circuit I was able to bend, ya a circuit you got to hack and weld the header .
A stock tomos right hand intake and a 14.14 sha is very blasty at over 50 mph with a mild pipe
https://www.mopedarmy.com/forums/read.php?2,3886963
ken-Is th bolt pattern the same? any case modifications?
Probably Fred /
> modifications?
Yes same
No mods to case
I use Tomos reed kits in puchs all the time .
Ken Roff Wrote:
> > modifications?
> Yes same
> No mods to case
Why?
Probably Fred /
Duran morley Wrote:
> Ken Roff Wrote:
> > > modifications?
> > Yes same
> > No mods to case
> Why?
Because cheeper more powerful then kstar pp kit and hi hi head and to use my tomos heads, reeds intakes/parts up.
The treats reed kit for puch has a huge goofy shape exhaust port that's too big for many pipes too, the 44 mm kit has better skirt, smaller exhaust port
I use stock tomos a35 reed cylinder and a55 cylinder on puchs too
Both have way more power then stock Maxi cylinders
interesting..Ill have to try it out..
