WTB: Moby Grips That don't hang off end
Bruce Zapper /
WTB: Moby Grips That don't hang off end,OEM or close to OEM Where to buy.OEM GRIPS ARE 4-1/2" Long.
Re: WTB: Moby Grips That don't hang off end
I used motobecane style over-engineering to solve the overly long grip thing. On the throttle side it's a short piece of copper tubing epoxied (pc-7) in place, with the nylon spacers inserted in the end of the "too long" grip.
On the left side it's just some oddball piece (of the right size) that I found at the hardware store, epoxied in place.
Bruce Zapper /
bzap OP
Good Idea Thanks!
I put "plugs" made out of nylon inside the end of the grip as well. I've also used stacks washers. I didn't connect them with pipe as above but once securely on they don't flop around or anything.
Bruce Zapper /
bzap OP
Great simple fixes Thanks
Steetmate handlebars. They are almost same dims with longer grip areas. It looks totally stock that way, then you can use any grips you want. Like smokin hot brown domino grips.
Bruce Zapper /
bzap OP
Nice! Thanks
