FS: E50 kickstart conversion kit
Chris Straub /
Mounted but never run, bought from treats when they still had them. $150 shipped, thanks!
Re: FS: E50 kickstart conversion kit
Have you tested or tried it out...other than not being able to roll start or pedal start what are the issues with having a kickstart...
Chris Straub /
I just assembled and saw how it mounted on a spare engine I had when I first got it. Never actually kick started a bike with it though. Been sitting on my shelf for too long so time to go. Also you need to drill and tap two extra holes in your case to run this.
being it takes a different clutch than a reg. E-50.....is one come with it...?
same clutch as a regular e50.
Supposedly the kickstart clutch has no padding on the outer side....is what Im told...
sookia sookia /
oem kickstart clutch did, this is a conversion kit that allows you to retain your stock clutch
Chris Straub /
Ya an original kickstart clutch will not work with this kit.
There's got to be somebody that had or has one and can give a truthfull review...how they last,,,weak spots,,,
Will Janssen /
It is a complete set i see and everything looks good on the photo .
And price is good .
I hope you Sell it
Chris Straub /
I appreciate that Will!
Chris Straub /
Pending
Chris Straub /
Soldahdo!
