WTB: V1 Clutch bell shims and Starter clutch spring plate.
These two shims one goes between the clutch bell and the crank shoulder, and one goes on after the clutch bell before the circlip. I can get by with just the .82 inner shim.
And this.
Thanks.
Re: WTB: V1 Clutch bell shims and Starter clutch spring plate.
pm'd
Would a range of different thickness V1 shims be desirable if I can put together some V1 shims pack- like I've done for e50 shims?
If so, what would be a good range of thicknesses to cover all possible scenarios? ID and OD?
I don't know jack about the V1....
I bought packets from mcmaster. you can get .8mm and .3. Stack the .3 ond you are good to go. the only thing is that you spend a measly $5 and end up with 20 though.
http://www.mcmaster.com/#standard-shims/=twce0y (edited)
I found some. Mcmaster was my plan B.
Ah. If they are already that easy to acquire than I won't bother.
Thx
Just use a hacksaw blade for the spring plates
