Wtb Magnum / Pinto swing arm
Need
Re: Wtb Magnum / Pinto swing arm
The Pinto swingarm is the same as a maxi, it's pressed steel. The magnum swingarm is tubular and a tiny bit longer than the maxi swingarm. Which one is it that you need?
Free spirit has same as magnum if that's what you meant?
Probably Fred /
A Murray has a good swingarm even a little wider then a magnum swingarm
Magnum, was told pinto was the same.
Have magnum w no swing arm so yea
campeona del mundo /
i have a magnum swingarm you can have. its got a side stand welded to it and its been repaired! 45 shipped...pm me
