WTB: ZA50 Oil Inject Parts
Garrett Bell /
Hey Mopedarmy!
I am attmpeting to rebuild my ZA50 all the way through, it was my first engine and I'm super excited to freshen it up with new bearings and crank..... The Works!
My ZA50 is not oil inject however so there are a few parts I do need:
First: Cluctch Bell from the Oil Injected ZA50
Second: Main Shaft from the Oil Injected ZA50
Third: Clutch Cover from the Oil Injected ZA50
If anyone out there can help me out I would greatly appreciate it!
Thanks all! Happy June!
Re: WTB: ZA50 Oil Inject Parts
Probably Fred /
Their arn't any specific parts indigenous to oil injected Za50s other then the crank and case bored for pump shaft and some za50s have big bushing end and larger ID bell some don't. I've even seen early year oil injected engine with the small size parts.
You want the bigger size parts I guess.
Without a oil injected case you can't run oil injection
Garrett Bell /
Ooooooo, I was confused I guess, on Mopedarmy it seemed to me that the oil injected clutch cover was the only one that worked with the za50 treats crank which is limited to the oil inject clutch bell and main shaft.
Kk so can I reuse all my small parts for the treats crank?
Thanks for the help!
Garrett Bell /
Ultimately, I could just measure and find out that way?
Probably Fred /
> treats crank?
No you can't use your small parts
I'm just saying not only oil injected has big parts
I believe that all you need is a larger bell any way
