One dellorto ds racing edition carburetor for sale. like this one http://www.treatland.tv/dellorto-PHBG-21mm-black-race-carburetor-p/dellorto-phbg-21-ds-race-2699.htm
comes with the parts for the cable choke also, since i bought those. comes with the stock jets. the plastic screw on thing for air filters on the back. everything it came with stock. except i bought the pull up choke for it. comes with a extra rubber fuel screw o-ring too. and the carb, just got rebuild this spring.
95$ shipped in continental usa. ill even give you 2 freaking weeks to set it up to make sure it works for you since it never worked for me and return it, your cost, back shipping, for your 95 bucks back if it doesnt tune to your bike.
also, jet kits. 2 main jet kits. dellorto brand. 75-98 10 jets. 15$ 100-122 10 jets. 15$. shipped. buy both, 28$ shipped.
malossi main jet box 6$ shipped. add one jet kit, 4 dollars$ is the price. both add it for 3$
bgm-pro needle set. missing or raped, 2 needles. them would be the w12 and w8. W3, W4, W5, W7, W8, W9, W10, W11, W12, W25.. minus them messed up ones. or missing. 12$ shipped.
i also have other needles. just about most of them. 7 $ each. shipped. buy more than 2 and their only 6 each. buy 5 or more, and the 5th one is 5.50 and there on. so 4 for 6 each then theyll be 5.50 each after. 1 or 2 are 7 each. shipped. i can write these down later..
ehh https://www.treatland.tv/dellorto-PHBG-fancy-lever-choke-p/dellorto-phbg-fancy-lever.htm that choke. for some reason it doesnt hold down. you can hold it down yourself. 12$ shipped. swap on the carb for 7$ more. with it for 10$.
number #30 throttle slide. hows about 11$ shipped.
also got, some clips. 2 total. the ones that go on the needle. 1.50 each or 1.00 with anything else you get too. shipped. and theyll come in an envelope with a stamp on it. probably inbetween 2 pieces of cereal box cardboard.
air filter screw on adapter 36mm 3.75$ shipped. its bulky plastic thing a ma thing. it has a couple dings. from prying it out of my airbox.
like au atomizers? how about 12$ each? AU 258-260-264-266-268-270. 3 then from there on up 11.00$. 5 then, 10$. so 1 is 12, 2-24, 3 35 4-46. 5 56$. 6 all of therm 66 dollars shipped.
oh yea filters. ill clean these or leave them uni oiled, and havent been sitting for too long. and havent been used much. http://www.treatland.tv/malossi-PHBG-RED-air-filter-E8-p/malossi-phbg-e8-filter-046199.htm
15$ shipped.
just got this one. http://www.treatland.tv/polini-peugeot-air-filter-p/polini-peugeot-filter-203.0010.htm 18$ shipped. not even 20 miles on it.
also, a straight uni-filter 32mm 10$
15 degree angled 32mm uni filter- 11$
38mm angled uni-filter, i dont need none of these, 13$ shipped.
costs on these are amount of use. i can reclean and reuni oil any of these. if you want it. not more than oh maybe 400 miles and left indoors. others, around the same, or the biggest one, not over 100 miles.
ask for pics ill post some later
i take paypal. we'll split hte paypal costs. negotiate. (edited)
