Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etc
Rob GasketFace /
I'm getting rid of stuff before I move. Some of it's good, some of it's crap. The good stuff is cheap, the crap is free (plus shipping). One man's trash is another man's Encarwi carb.
Add shipping to all prices if you can't pick it up in Pittsburgh.
I'll powder coat any metal parts black or blue for an extra $15.
First photo:
- 44mm puch airsal kit (70cc) with piston. In good shape. $50.
- Honda 70cc polini kit. Comes with everything in the treatland link. In perfect shape. Ridden for less than 10 miles. $80.
- Stock NC50 cylinder, head, piston. $30.
- Two treatland CDI box, external ignition coil things. Might work, might not. Free.
- Scooter external ignition coil. (This one:
https://www.amazon.com/dp/B0058KVQY6/
) Might have weak spark, not sure. Works with Chinese 5-pin CDI boxes. Free.
- 12V horn. Free.
- Puch magnum pedal crank shaft. Sprocket might be slightly bent out of true. Should be easy to fix. $10.
- Tomos 20T rear sprocket. Bent out of true, should be fixable. Free.
- Stock NC50 metal reeds. Free.
- Air filter. About 1" ID. Free.
- External condensor. Never used. $5.
- Flywheel from treatland ZA50 kit. Sheared keyway. $10.
- Brake spring thing from an A3. Free.
- Rubber air filter adapter? Not sure where this came from. Looks like it converts 60mm ID to 40mm ID. Free.
Second photo:
- M bars. Never used. $10.
Third photo:
- 1978 Honda Express body parts. Some pieces are rattle can painted. License bracket is missing the headlight mount (I cut it off). Ask for prices.
- Express gas tank has two pinholes. Holes drilled between gas and oil reservoirs so they're combined or whatever. A little rust and a lot of peeling varnish on the inside. Severe paint peeling on outside. $25.
- Full cable set: throttle, front brake, rear brake, speedo. $25.
Fourth photo:
- Two stock A3 cylinder and heads, one piston. $15 for each set.
- Stock A3 sprocket (24T I think). Free.
- A3 front fender. $10.
- Encarwi carb from A3. Free.
- One A3 clutch shoe. Free.
- A3 speedo. Doesn't work, but probably fixable. Free.
Last photo:
- Biturbo exhaust. Fits a stock A3 cylinder, A35 70cc airsal kit, and others. Rivets replaced, but baffle is still very wobbly. Recently restuffed with fiberglass insulation. $10. (edited)
  Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcTopic by: Rob GasketFace Rob GasketFace 05/30/14 08:38PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Steve Smith Steve Smith 05/30/14 08:59PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Monti S Monti S 05/30/14 09:10PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 05/30/14 09:45PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 05/30/14 09:53PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Jonathan Greene Jonathan Greene 06/04/14 10:22PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: charles baker charles baker 05/30/14 10:25PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 05/30/14 10:28PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 05/31/14 11:18AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: jaime diaz jaime diaz 05/31/14 11:57AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 06/01/14 06:03PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Steve Smith Steve Smith 06/04/14 09:24PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Monti S Monti S 06/04/14 09:44PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 06/05/14 07:22AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 06/14/14 10:16AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Scooter Steve Scooter Steve 06/15/14 02:16PM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 06/16/14 12:25AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: Rob GasketFace Rob GasketFace 06/17/14 01:23AM
  Re: Moving sale. Free and cheap stuff: 70cc E50 and Honda cylinders, stock A3 and NC50 cylinders, M bars, Express and A3 body parts, cables, Biturbo, etcRe: geoff ballou geoff ballou 06/25/14 11:18PM
