WTB - Bat M56 transmission chain and carb
Brent Bublitz /
Just got a Regency. Putting the motor back together and found there are a few missing bits. I need the transmission chain that connects the pedal shaft to the engine. It is -not- a standard bike chain. It's listed as 3/8 x 5/32.
I also need an original carb, or a custom intake that can handle a clamp SHA or Bing. On the M56 the carb mounts with a flange directly to the motor, no intake, so any M48 stuff is a no-go.
I could also use the left side engine cover and the lower bodywork, but those are secondary to the other parts.
Re: WTB - Bat M56 transmission chain and carb
Brent Bublitz /
bumpskies.
I have a chain for you and I also have made custom m56 intakes for people in the past that fit 16mm SHA's. PM me if you are interested.
https://flic.kr/p/aprijf
https://www.flickr.com/photos/42550941@N06/6172426210/in/photostream/
Brent Bublitz /
rump-a-bump
First I guess I should inquire that the majority of the stock carb on my m56 is good but the throttle slide/choke cover (made of plastic???) has fallen apart. If that renders it useless fine, I want what you have.
Thanks in Advance, sending you a pm .
