FS: many Moped Stuff(s)
Senor Juanito /
Puch Speedometers with cable, $11 shipped
Puch Wheelset Spoked Thick Version $150 Shipped
Stock cylinder, Piston rings & wristpin in running condition $25 shipped (Hi torque)
Stock cyl piston rings & pin in running condition $20 shipped (lo torque)
12 bing in good working condition $25 shipped
Levers (just the levers) not the whole assemblies, $10 shipped for the pair
Puch ignition coil $ 12 Shizzipped.
Puch rackz $9 plus shizzipping
Puch Brake plates Front 16 shipped including pads.
Puch brake plates rear 16 shipped including pads minus return spring SOoosorry bout dat.
Used puch brake pads complete set good meat on em', $12 shipped 80mm
Puch handlebar clamps $10 shipped
OEM Puch Clutch 2 shoe, $25 shipped good shape
Puch Stock Crank $35 shipped
MOBY headlamp assembly with nice condition ring 15 Shipped No sealed beam
Moby headlamp assembly nice ring, $20 Shipped with Sealed beam.
Moby Clutch Drum $10 shipped use em as clutches or make a great ash tray!
Moby Bottom end, FAG bearings, new seals, stock crank, no variator or magneto Rebuilt, never used. $70 shipped
Moby Front Brake plate Plus pads, $20 shipped
Moby kickstand NOT bent. good shape, $20 shipped
Moby Chrome : you name it , i got it.
Moby intakes, Long curvey ones that fit dellortos $10 shipped
TOMOS
A35 Cylinder piston rings and wrist pin $30 shipped running shape
a35 cy piston and rings wrist pin, **broken exhaust stud $20 shipped running shape
a35 magneto covers, x3 $25 shipped good condition, black
Set of white tomos mags, $90 shipped, near flawless condition straight and true. no cracks.
Minarelli Shitz,
v1 Stock piston and cylinder, $30 shipped
V1 stock head, rounded $20 shipped
Those two together $40 shipped
V1 side facing intake $10 shipped
Any assorted bing shit. ask about it. I;ve got a box full of bing stuffs
Re: FS: many Moped Stuff(s)
I'll buy the puch crank if you still have it.
Is everything cash only? Or will you accept trades for parts?
