FS: SACHS, 70cc athena, snowflakes, giannelli pipe, 504 bottom/carb
First off, brand new 70cc athena. Complete with jug, intake, piston, ring, wristpin/clips and the exhaust adapter thing. Never started, was put on and pulled off. decomp plugged. $200 shipped
Set of snowflakes bought off treatland as sachs. Comes with brake plates and axles. no tires. $100 shipped
Giannelli sachs pipe. Used for awhile on a stock setup. Maybe 30 miles. $50 shipped
504/1A complete bottom end. I also have the square bing i could throw in complete with airbox. was running good at one point but hasnt been started in over a year. $100 shipped.
Re: FS: SACHS, 70cc athena, snowflakes, giannelli pipe, 504 bottom/carb
Tri-ped Dave O.D.B. /
What size diameter is the intake?
Would I just be able to get the sprocket off that back wheel? I have a set of sachs snowflakes that I need a 40 tooth for.
have the stock end that was on before the kit?
OhfuckohfuckohfuckOhfuckohfuckohfuckOhfuckohfuckohfuckOhfuckohfuckohfuck......
must....
.....resist.....
......buying......
..that....
........kit........
Intake is 15mm. I would like to keep the sprocket on the wheel as they might be spoken for.
I'm sure I have the stock top end but def no piston.
Buy the Athena dood! Might not see one for awhile and this is a fresh gasket away from bring brand new.
Any chance you'll come down on the kit a little?
Sorry kit and bottom end are sold.
Wheels/pipe pending payment.
