FS: Tomos Voltage Regulator (several)
Timmy Southpark /
I have several voltage regulators. $17 shipped each. Buy 2 for $27 shipped,
email if interested.
Re: FS: Tomos Voltage Regulator (several)
Email sent requesting pics.
Pic!
Timmy Southpark /
See attached
i'll take two, but i'll be pissed if theyre burnt out!
emailed..
Timmy Southpark /
these were pulled from parts bikes several years ago, i guess i really dont know if they are functional or not, but they typically dont go bad.
So if your leary, perhaps dont buy. Sold as-is. I would like some extra cash, but these are not bad items to have laying around, Ill use them eventually if they do not sell.
i have two right now that dont work, they are nice units, but somtimes they can burn out.
any way you can test them?
Timmy Southpark /
I dont really have a bike current setup to run one or I would try. Can you use a multi tester to check these?
i think if you put over 12v into the left side horizontal pole, it should come out on the middle one lower or at 12v. ground the right side vertical pole.
it's AC too.
I know how you can test them....
I wouldn't put 110vac to them or they will probably burn out for sure. A regulator will probably fail open so a multimeter will show no continuity or zero ohms on a multimeter in both directions. if only zero ohms in one direction and a measurable reading in the other, its most likely fine.
just like a rectifier then.
anyways , i bought all of them ( :
Those are half wave rectifiers - they may very well be diodes. Full wave is just a diode bridge.
Timmy Southpark /
All sold and shipped, thanks Sabat!
Salty, call me some time.
Kevin Bishop /
do u still have? can i buy 2?
Sold!
Timmy Southpark /
Sorry, all are sold. Thanks -Jimmy
