FS V1 Partout Cases, Clutch, and Clutch Cover
I have decided to part out this motor, already sold are the ignition, and the clutch drum/spring/plate are all sold to me for a ktm set up.
the crank is a roller bearing (not full circle) BUT it has damaged threads on the clutch side. maybe you can repair it to a smaller nut size, or clean up the threads IDK, i didn't know it was a reverse thread and so i stripped then cut it off.
I put some prices up there, the cases have all the gears in them and the pedal shaft ect, the crank probably needs to be rebuilt anyway but whatever......
-35$ Clutch cover with lever, good plate W/Ball Bearing, fill hole screw, check hole screw
-30$ Clutch (with wire feed welder tacks on the pins, disassembled for your modding pleasure, or can reassemble for you if you want) unbent plate with good threads,Great Pads as always/ complete
-40$ Cases with all internal gears/pedal shaft/output shaft, damaged sprocket(sharp)/busted crank, original transfers, unmolested
In the pics what you see is what you get, ask if you want to know about specific specifics like a missing bolt or something else really small.
Also ask about odds and ends i may have the case hardware complete or something.....
All prices include cheapest shipping possible with delivery confirmation, PayPal
Email or PM
(edited)
Re: FS V1 Partout Cases, Clutch, and Clutch Cover
BOMUPOEIPOIPOOB:ULBULUBLUBUBLBUUBUBUUBOBOBUOBUOUBLLbuuliu
POP!!! Back at the top
Arnie Sparaco /
is the stator plate for sale? if so how much?
> up.
> (edited)
Holler
>>>taykoff [s2m] /
I will take the clutch...hit me up!
Clutch is sold, ship tomorrow, thanks!!
BUMPS
i know someones clutch cover starting lever ball arrangement is about to wear out, or has a crack or something.
holler, ad case induction on this spare case, who cares.
BUMP
Pickup at WLR rally
need the output shaft. hold it for me when i come to the rally?
you want just the shaft? just buy the case, gets you spare gears and the actual case also .
I will knock 7$ off the price for pickup. so 33$ you get the damaged roller crank in there for free (kinda) think about it.
emailed about the clutch side panel thingy
Well two people told me "I'll take the clutch cover if you still have it"
I still have it, wierdos. anyway bump paypal me.
bump
and I bump \
Wheee
For Dan O
ok i snapped a ring and gouged my metrakit, help me get it overbored before my OWN RALLY, i can't be going 35mph on home turf!!!
Buy this Crap!!
emailed
anyone for 60$ shipped for the cases and left side cover??
payapl with tracking.
or picked up at WLR SoCo III
55$
BOOM
it is that time again
, time for bumping
BOOOOOOOOPp
can take better pictures, split the cases to get the old V1 roller bearing con rod out.
is that needle bearing conrod or bushing?
Already traded the con rod roller bearing.
still have the cases cover and gears though....
package deal, holler holler.
Huzzah!!
do u have another ignition coils points and condenser ?????please let me know or if you no of someone else thanks
No, post a wtb
Clutch SOLD
just cases with gears and shafts in them left, go nuts put a cb750 cylinder on there. or try at least. weld grind polish, have spare gears. go for it. !!!!!!!!!!!!!!!!!!!!!!
