WTB: Hero Puch 65cc Kit - Paypal ready!
Timmy Southpark /
https://www.treatland.tv/puch-65cc-hero-massive-port-kit-p/puch-hero-kit.htm
Looking for a hero puch kit like above link. Used or new, doesnt matter to me. I will pay a fair price for used or buy your new kit for full retail plus shipping. I just want to try this kit out.
Id also be interseted in 65 metrakits, puch polinis, and etc...
Let me know, paypal ready.
Re: WTB: Hero Puch 65cc Kit - Paypal ready!
I got one for ya! I'll even throw in an motion left intake for a little extra
Timmy Southpark /
emailed
delete this account /
bump, looking for a hero kit for my korado, if not I'll just crack down and get a polini
MaddMatt -Ruffians STL /
I may have one but It might need a piston or rings, I would have to check my stash.
Timmy Southpark /
emailed
anybody have just a piston and rings? i have 2 jugs that i need them for....
can you use mk 65 pistols? Maybe a difference in ring gap position?
My cylinder lost a circlip, so it has some scratches in it. I also have an over bore piston, new so you could bore the cylinder out and be in business. I have the stock piston that would probably work if you got some rings and clean the cylinder up a bit. Boring it out and using the overbore piston would be your best bet. I would sell the cylinder and both pistons for $25 shipped.
if nobody above wants the stuff maddmatt is selling ill take it just let me know thanks
My hero kits sold.
i also have one of these its brand new run once and il prolly never use it
if anybody wants it il sell it but you have to be a bit patient as im in the hospital right now and i dont know when il be out
but yeah email me
i just thought of something a hero puch kit is not gonna bolt right on your korado
hero has a different stroke than a regular e50 so if you wanna use this kit on an e50 you will need to use a spacer under the cylinder
so if you are buying one for your korado dont buy a regular puch kit for it
dude, new77 has em back
oh nope. notyet
Not one version of the hero has a different stroke they are all 43mm the e50 za50 and z50 there's probably another one but they are all the same as puchs.
plus people are already running them successfully
ok you dont wanna believe me buy one and find out
Got one riding it yesterday
the stroke of a hero engine is a lot shorter than that of an e50 but i only built them so i must not know
it will run but not run right since the compression will be low and the port timing is way off
i layed my out and its about 2 mm off and i guarantee my e50 is not different than your e50 the hero has a shorter stroke
i been building engines for 15 years i know what im talkin about
TECHNICAL SPECIFICATIONS OF HERO PUCH AUTOMATIC
ENGINE
Power 4.15 BHP at 5500 rpm
Type Single Cylinders, Two Stroke, Air Cooled, Spark Ignition, Petrol Engine
Bore 43.5 mm
Stroke 43.0 mm
Displacement 64 cc
Transmission Crankshaft to rear wheel through centrifugal (automatic) clutch, single speed constant mesh gear train and roller chain
CHASSIS
Frame Type Box Section Frame
Wheel Base (max.) 1100 mm
Ground Clearance 130 mm
Dry Weight 67 kg
SUSPENSION
Front Telescopic Fork (80 mm Stroke Length)
Rear Swing Axle (50 mm)
BRAKES
Front Internally expanding, 80 mm brake drum dia
Rear Internally expanding, 110 mm brake drum dia
TYRES
Front 2.25" - 16" : 4 PR
Rear 2.5" - 16" : 6 PR
IGNITION
Ignition Flywheel Magneto Ignition System (CDI)
ELECTRICALS
Head Light 6V, 25W
Tail Light 6V, 2W
Horn 6 Volts AC
Speedometer 0-80 kmph Range
Mileage 89 Kmpl (under standard test conditions)
Source: http://www.herohonda.com/
i dont think its right like i said with this kit on the e50 the piston didnt ever come close to the top of the cylinder
this is my experience with it its either its a shorter stroke or or like most stuff the quality control sucks and some cylinders were cast wrong
the port timing was all fucked up see i know im not wrong so you can say what you want
Jason, I think you meant to say the deck height is different.
I just don't understand why if the piston doesn't come close to the top of the cylinder would you then advise to run an additional 2mm spacer under the cylinder.
