needed PHVA parts carb
need a busted PHVA 17.5 with all its air screws and ity bittie peices. if the body or float blow is messed up or not sealing up i still want it.
Re: needed PHVA parts carb
I have a 14, but I don't know if the internals you want are interchangeable. Let me know if interested.
IF ITS A PHVA 17.5 DELLORTO it should be fine what kind of choke is on it?>
ill give it a try at 30bucks
Timmy Southpark /
I have a 17.5 and a new 14 PHVA. Both missing the top slides. Make offer. The 17.5 has a complete manual choke assembly. Both carbs have floats, air needles, jets, and etc... Just no slider, spring, needle jet, or top.
mine is complete, have cable or pull choke (lever), body has been drilled and cut at the mounting end to change from spigot to clamp style for moby bendy intake.(18mm od of intake). again its a 14 phva. have 6 0r 8 jets also
Timmy Southpark /
Well mine can kick yours ass!
no,..... your's won't even work..hah!
well jimmy ill offer you 60 for the 2 carbs maybe 70 for some spre jets
like i said before mel ill offer you 40 for your carb and ill do 10 more for some 6-8jets
I'll let it all go (complete carb with both style chokes, and 9 total jets-64, 66,68,70,72,74,76,78,80), for $65 shipped
deal!
Timmy Southpark /
emailed
emailed pics
