Lotsa parts: DR, Polini, Hobbit, Vespa, 13 SHA, variators, cases, wheels, forks, cylinders and more
Dominic Valentino /
All prices shipped, make best offers and trades? Email or pm
Looking for:
big boy hobbit intake/reed setup
good rear hobbit var pulley
top tank gas tank
front disc setup
hobbit kickstart
hobbit h20 stuff
hobbit stuffy crank
tjt var
more, larger pics here
Misc stuff
13.13 del'orto SHA relatively new (has slide, not shown in pic) $45
6v horn beep $8
CEV glass bulb modified to take auto bulbs nice $8
VESPA STUFF
case/dr kit built no ignition, no decomp. spring, runs great $125
ignition both coils, ht coil, points, no bolts $25
no pics
2 flywheels points style $15 each
clutch single speed, all there $25
no pics
front wheel 17" w/ tire no flat incle brake $35
rear wheel w/tranny single speed, smooth, 17" with tire hold air flat, no pulley $55
variated tranny gears just the gears $12
no pics
ax36 for variated ciao barely used $6
ax36 for variated ciao new $8
ax35 barely used $6
Olympia variator windowed but sticks; add some quick steel and be golden/fast $18
vespa speedo 40mph $12
front/rear fenders slightly dented, includes brake light! $18
rigid front fork good shape $20
springer front fork good shape $30
Stock Cylinder good shape, clean bore! May have piston/maybe not? $18
stock head good shape, w/decomp, may have decomp spring/ma b not? $20
see above
Kinetic crank good shape $15
Kinetic case botched intake job so add some jb, rock out $15
piaggio case just a stock case, naked $20
no pics
Polini base gasket metal, new $3
SHA stock airbox $3
HOBBIT STUFF:
PAII variator no back plate, has weights $35
PAII variator has back plate and weights $45
bar mount bottom just the bottom piece, mount yo light lower! $6
floor cover murdered out, rear hole broken $8
PAII bottom end crank/clutch, no clutch bell no pulley/ cdi stator
no flywheel, crank thread jank $43
PAII cylinder no piston, nice, clean bore $18
PAII cylinder cylinder/piston/needle bearing/pin $38
PAII head good shape, incl de-comp, incl spring $30
polini piston/rings/pin barely ran, good shape, no damage. just some blow-by $30
speedo great shape $12
tjt spring brand new in packaging $8
three signal lenses good shape $3 each/$7all
nice stock crank great shape, one less than good bearing, one great bearing $25
cdi cover $10
hobbit fork cover good shape $10
Hobbit frame straight, no vin plate, yeah, tail chopped $30
solex seat cool like a ciao seat, fab to fit your ped $14
Re: Lotsa parts: DR, Polini, Hobbit, Vespa, 13 SHA, variators, cases, wheels, forks, cylinders and more
Dominic Valentino /
sha gone
I definitely want the new ax 36 belt, and the the 35 if its toothed.
I may have to buy the vespa case / dr also! (edited)
Dominic Valentino /
dr and belrs yours for 120 ? dealz
ive got a 24oko with a matching dio four petal reed block and intake, plus all the jets and needles youll need to tune plus a carb rebuild kit, 90 shipped? you did say big boyy
Dominic Valentino /
yeah we pm'd, I've got a vm28 already, sell the intake/reeds alone?
Dominic Valentino /
@brad, al three belts are toothed
Dominic Valentino /
hobbit variator without plate gone
Thunder Tribe /
PM sent
Dominic Valentino /
replied
Dominic Valentino /
solex seat, lenses gone
Dominic Valentino /
dell'orto filter box gone
both vespa cases gone
Jumper K. Balls /
Is the wristpin on that kinetic crank 10 or 12mm?
Dominic Valentino /
i'll check in the morning and reply back, thanks
Dominic Valentino /
Small end I.D. of the Kinetic crank is 12mm.
On closer inspection the threads on the shaft are just slightly off (pics below) but they should be useable as is or easily repairable with a tiny amount of filing. Also a mm or two has been cut on the intake side/edge of the crank lobe.
Dominic Valentino /
All purchases have been shipped. Tracking numbers emailed if available. Thx
Also,
Hobbit horn cover/fork cover gone
Hobbit head gone
Dominic Valentino /
ramp plate from remaining hobbit variator gone, variato/weights still available
Dominic Valentino /
dr engine gone
vespa speedo gone
Jumper K. Balls /
Sorry. By wristpin I meant the hole where the piston pin goes through the end of the rod.
Dominic Valentino /
yes that measured 12mm
Jumper K. Balls /
bummer for me. Thanks anyway
Still have that tail light? If you do, I'd like to buy it. What do you want for just the light shipped to Colorado?
Dominic Valentino /
david: pm'd
King Of Kings Moped Army /
Do you still have the running vespa motor? What size crank does it have?
Dominic Valentino /
sorry the dr engine has been sold
Jumper K. Balls /
Aww hell. Screw it. For 15 bones shipped I will take that 12 pin crank. PM sent
Dominic Valentino /
To verify the way I've measured the crank:
Dominic Valentino /
modified cev lens gone
vespa head and ignition bits gone
hobbit bottm handlebar mount gone
Dominic Valentino /
tail light gone
kinetic crank gone
Randy Andrade /
I'm interested in the speedo!
