wtb: derbi flat reed variator nut and cooling fan
Anyone have a Derbi flat reed variator nut and cooling fan laying around?
Re: wtb: derbi flat reed variator nut and cooling fan
bump
the fan isn't necessary, it does look cool though.
the variator nut... you will have a hard time finding that I am sorry to say. if I come across one I will throw it your way.
if could probably make on real quick if you let me know what the thread and pitch are.
naz i have one i can send you to copy
Ooh I would want one.. or even two.
me too, so I can send you one that is kinda mangled but the threads are still good, I just have no clue what size it is. I can try and find out.
Actually, I think I have one. So no need to send one to me just contact me with your info etc and I'll try and send some out to folks. I might need to order some tooling so that will slow down the turn around, fyi.
-naz
I'd be down for two as well. I'm missing one, and dang I could use another.
The variator nut for most is 36x1, fine thread
the internal nut (attaches to crank) is also fine thread + has a rubber o ring in the middle on flat reed
I have an extra variator nut 36mm but still would like another small nut for the piston port clutch bell (15mm x 1)
rare nuts
I have made one by using a 3/8" allthread coupling(Home Depot). You can drill out the coupling using a drill press and an 11/32" drill bit.(closest American size availible) Once that is done, you need to purchase a 10mmx 1mm left hand tap.(ebay,cheap!!!) Tap out the threads and it works great!!! I just thought that maybe someone had a spare nut and fan that they would be willing to part with. Hope this helps those in need.
http://www.onlinemetals.com/merchant.cfm?id=12&step=2&top_cat=1
I was just going to use some stainless hex bar to make them so they would be little bit different then stock and use the 10mm x 1mm left hand tap. Also cut the o-ring grove in on the lathe. Anyways doing all the operations on the lathe shouldn't take long so they will be pretty cheap.
-naz
I'm in.
me too
