Wanted Honda Hobbit Carburetor internals
Stock Honda 1978 Honda Hobbit PA50ii
I am interested in the float and the float pivot from a used carburetor.
thanks (edited)
Re: Wanted Honda Hobbit Carburetor internals
Is it the same as express float and do you mean the little pin that the float rides on or the thing under the float that allows gas into the bowl?
I tested the float and it is fine, I'm actually just interested in the pivot (pin the float rides on) at this point.
I can check to see if I have one tomorow and if I do then I'l let you know.You could easily make one out of a paperclip or something similar
I've tried that, it doesn't seal the needle just right.
I have several Ford Carter YF carburetors to rob from, unfortunately everything is 3 sizes to large to fit the Honda carb.
I believe the Express float pivot should match as well. If you have one laying around though, just message me.
thanks
