bare e50 bottom
Probably Fred /
A little dirty on the outside but seems clean on the inside.
Crank bushing is ok, crank moves nice. bearings seam ok
No clutch, no covers,no electrics but clutch bushing, shims, c clips and crank flywheel side woodruff key. Uncut cases what you see is what you get
Put on your parts from your old clapped out or broken case e50 and blast
it may work fine without rebuild.
63.00 shipped in USA
