super clean, runs, needs a new clutch cable tho, you have to use vice grips to start her up, also needs a pipe, as you can see from picture only a little bit of it is there, not sure where the rest went... tank is clean inside seat has no rips or tears, even has original tool kit in perfect shape under the seat, 40mph speedo, 2 speed Motori Minarelli engine, $500 obo located in upstate ny, corning
