So I have decided to be a jerk and sell this Magnum Mk II that I just picked up.
I would love to sell it locally, complete, and I want to get 600 Doll Hairs for it.
I have plenty of time to wait on it and have no doubt I could part out the whole thing and get the desired 600, I did the math.
So there it is.
Missing the center stand, under tank metal covers, controls, and some small misc. hardware like chain tensioners and an axle for the back Puch wheel. (has a jank wheel on it now from a trac, have magnum sealed bearing rear and brake plate)
Comes with
• Tank, CLEAN only the very slightest haze of rust in the very back corners and a few small dents, pictured 7 out of 10
• Frame, looks straight to me no welded or hacked pieces 8.5
• Seat, Foam is great, even smooth supportive, cover has small tear over trunk 7.5
• Trunk, all there no cracks, paint is real weak but to be expected W/lid and spring backed screw that fits, works proper, again NO cracks or damage to the trunk! Sweet!! 8.5
• Swingarm, nothing to say fits whatever Puch and lets you run awesome tires 9
• Pedal Shaft straight long 2 speed pedal shaft, will need spacers and maybe that plastic shim that fits in the frame? I have never messed with these. Arms suck,,, welded 7
• Wheels great chrome spokes wide wheels, stronger? SEALED bearing (missing axle and nuts for the back wheel, 45T sprocket brake plates may need pads 8.5
• Za50 motor complete, damaged cable adjuster but does work, leaks around it maybe cause I overfilled….. I couldn’t get spark, maybe you can Black topend, 18T sprocket 12mm, Bing, smooth looking cover 7
• Back fender only, has Superman taillight, not sure about that, good chrome 7.5
• Fork brace over front wheel, bolts on the forks, good place to attach a fender if you have one or I could dig around for a maxi one maybe….. 10
• Front Forks, Seized…… so probably hydraulic but IDK they are just stuck, comes with both rubber boots and cable guides, those look nice, forks have some tape on them 6
• Shocks Magnum sized, were nice, could probably be masked off and painted, then steel wool polish the chrome springs and they will look minty…..from 10 feet away!!!! Also had tape on them for some reason 7
• Headlight nothing fancy just a regular non bullet round puch headlight. 7
• Oil measuring cup white has holder, awesome Nuff Said 10
• Side covers, Black some evidence of hacking, ehhhhh… the posts for mounting them are still there on the frame so there is hope 7
If you want some particular part, send me a PM and I will get a list going, If no one buys it complete after a while I may price everything individually and respond to those PMs in order received. Or just respond to everybody at once and post prices, Who knows just buy it all together.
Will consider shipping, if you arrange EVERYTHING or I could keep it at my house for a few bucks until our rally, in SEPTEMBER when you come or send someone to pick it up…… (edited)
