For sale…
Complete Motron Medalist- anything you see… This was listed for my buddy, but email me.
1) V1 (needle bearing) motor w/ new 75cc polini top. Has aftermarket CDI from 77 I believe. Motor is in good shape, never put on the road but ran a few times. Comes with dellorto 14/12 & intake. Newer EV pipe. $350 to your door.
2) Tomos mag wheels, gold in color. Really nice shape, tires are nice. $120 shipped with all hardware and tires.
3) Everything else $50 for pick-up (drag bars, controls, tank, etc…) If you want the wheels with the frame $140 pickup only for all.
4) Extra tranny not in pics. Side cover pulled but everything there. Rod is tight, good lower end. $70 shipped.
80cc Metrakit on E50 (Koroda gears)
1) 80cc metrakit, I can not remember if it is large or small part. $210 shipped. Never been ran, comes with everything a new kit has but probably needs new seals.
2) E50 tranny - brand new Rito stuffed crank, new bearings & seals. Engine cases were welded to accept 80cc metra kit. Korado internal gears (clutch housing, reverse cut gears) but in a 4 bearing case. Comes with new 3 shoe clutch with reinforcement plate (clutch still needs to be installed) cases have neen cleaned, just alittle dirty from sitting and assembly. Crank & bearings have never been ran. No electrical. Should have some clogs to throw in on the deal. All new allen head bolts. $330 shipped (over $400 invested) I’ll sell the motor with the top end for $520 shipped.
3) Koroda cases (ready for porting for large bore) with stock koroda needle bearing crank. Comes with stock E50 clutch & housing (not Koroda) All in good shape. $80 shipped.
4) Homeot 8p exhaust. I jb welded a piece of tire to damped a puch kickstand in the up position. The pipe flaked off at header, so will need to be painted. $110 shipped.
Misc:
1) Newer style tomos mags, really nice! Good brakes, all hardware. $100 shipped. $145 shipped with tires (brand new 3 inch wide rear).
2) 21 PHBG Dellorto race edition w/ clear float bowl. Never touched gas. Comes with intake made by fellow MA member for Puch, intake could use some cleaning up. $130 shipped.
Emails please. (edited)
