WTB: Hobbit 2x Throttle Cables & Tank Petcock
- Summerai - Pwnerer /
Need 2 cables
& 1 Petcock
Also need a piston if anyone has one!
Thank you!!! (edited)
Re: WTB: Hobbit 2x Throttle Cables & Tank Petcock
bicycle brake cables work
use the walmart bicycle cable pack. A hobbit thottle has one knarp so there is a cable in the pack that would work out of the box I think. Trim the cable and housing to length and maybe grind the knarp down if it catches in the throttle tube.
Buy a new cock from treats for $13
gO WITh the expensiver OKO clear petcock, iz awesome!!!!! if you don't have stock shocks, don't though. the bowl is a little longer than normal.
Its cool having a blue cock at the bottom O_O
you know
because
its
clear
and my premix
is blue
coloured...
GEEZ
seriuosly
hit up walmart
and
treats
pm me if you need a stock petcock that leaks v___v probably can be had cheap xD
and umm the oko petcock comes with a little clear/round washer thing, that is the 'crush' washer for the petcock. it works well. Not a drop leaked well worth whatever i spent on it. Just dontwant you to think thats garbage or something, its a washer, seriously and it doesn't leak.
No one ever told me, but I figured it out. kthx (edited)
Thank you for the suggestions! I will try walmart tomorrow for those cables. Also I just saw that treats has some hobbit compatible petcocks for sale so I guess i'll get one of those.
I made this photo a month or so ago
Boom
