FS: Moby clutch/variator
Re: FS: Moby clutch/variator
You need a special crank for nonvariated motobecanes? I thought this was a direct switch for the dimoby on a 40t? If so, I'm interested in it (edited)
Direct swap on Moby. Peugeot needs a crank swap to add the vario.
Also 3 ball vario shifts later than the 4 ball vario does unless you remove 2 balls from the 4 ball vario then the 2 ball vario will shift later. (edited)
I'd do $50/shipped. Pretty much covered by what you'd lose in ebay fees.
