Re: looking for a cheap puch near RI
P Filip /
Hi Reed, I just acquired a project Puch that is turning out to be more than I wanted. It's a 78 Puch Maxi which was spray painted blue, sat outside for a while, has a clean gas tank inside. I just took apart the motor today, connecting rod is seized, piston is broken, cylinder is scored.
Basically a project that needs the e50 engine rebuilt, and will need a new top endIt is mostly complete, I did not notice much missing besides the air filter box and side covers.
$110, located in the center of CT, Wethersfield, CT.
I figure that if you add between $100 and $150 in parts you will have a nice running Puch with a rebuilt engine.
