WTB Tomos stuff
Morgan Stabler /
Would Like to buy all this at once but if not its all good.
1. Throttle Cable
2. Brake Cables, front and rear
3. Nut to hold shock on
4. One of the three bolts that holds on the engine
5. Rubber Mount under the lx gas tank
6. Crown nut
7. Throttle slide
8. Replacing 1st and 2nd gear clutches, so need all new clutch pads
9. Two Replacement piston rings 44mm (for 70cc kit)
10. Left side controls
I also need a Puch clutch cable, idk if it matters but its for the za50
Thanks (edited)
