Up for sale is my partially restored Puch M50 (european only model).
Decided to part with it after all these years.
Looking to get $1600 for it, title and plate in hand.
Bike is located just south of SF in Pacifica CA
Contact me @ chrispaz@mopedarmy.com
Bike was completely stripped down, frame was powder coated gloss black.
Tank was powder coated and beautiful metallic green pearl, fork guards headlight and side panels were painted to match.
Swingarm, fork lowers, shocks, rear fender, f&r brake plates & rear sprocket have all been painted.
Motor has been completely rebuilt with fresh bearings and seals + a roller bearing crankshaft has been fitted.
In addition rebuild motor has:
70cc Arisal cylinder kit
21mm PHBG race carb
Reinforced clutch spring
Expansion chamber exhaust
Really fun bike dose a solid 45mph (can get more out of it with an smaller rear sprocket).
To make the bike really special I would suggest the next owner recover the seat. It works fine currently but you can feel the padding is tired. In addition the wheels should probably be stripped and power coated. The bearings were cleaned and repacked and the pads are relatively new.
(edited)
