505-1D engine for parts
I have this Sachs engine. It came off of a Cosmopolitan. Was not a runner when I got it. Has hole the size of a quarter in the top half of the case in front of the drive gear. Looks like the chain broke and kinked when it went around the gear and popped a hole in the case. Pic shows hole as best as my camera phone will. Turn the crank and the piston and gear shaft rotates. Also have the cylinder. Sparkplug hole is a bit rough but run a tap through and you should be fine. Filthy inside but does not look scored.No decomp present. Good for parts or maybe someone handier than me can repair the case. Cash offer or trade for good vintage stereo receivers (70's and older)
Re: 505-1D engine for parts
Kevin Carl /
Sorry...here's the pics
Kevin Carl /
bump
Sent you a PM.
