Honda Express Nc50 and Na50 parts
Make an offer min shipping rate $10 may very on weight size and quantity.
Stator covers (edited)
Re: Honda Express Nc50 and Na50 parts
Preston Timmons /
Pegs, Speedometer, honda gooseneck collar
Preston Timmons /
Carb/intake mounting brackets
Preston Timmons /
Front fork rubber bushing mount, na50 cylinder heads
Preston Timmons /
Reflectors, 49cc jug, front brake caliper with brakes
Preston Timmons /
Brake leaver rubbers, petcock, right break leaver
Preston Timmons /
oil line, carb with gas and oil injector, carb for na50 2 speed motors vacuum and auto choke system
Preston Timmons /
Na50 air box, Na50 air box with right side cover, kicker
Preston Timmons /
Nc50 Na50 front wheel, Na50 wheel wheel, Nc50 Na50 kickstand
Preston Timmons /
Nc50 Na50 Mufflers, Na50 Seat and bracket
Preston Timmons /
Nc50 Na50 front struts, 1980 Honda express II wiring harness, Auto 2 speed motor
Preston Timmons /
Na50 frame rail, Nc50 Na50 headlight bucket, Na50 Gas tank
Preston Timmons /
1980 Honda express II frame, Frame plastic cover
If you still have the na wheels do you think a NC wheel would fit on that na rear or vise versa?
hows the rubber seal on that gas cap? if its in good shape wanna sell that gas cap to me?
Whats the story on that 2 speed setup?
kim jensen /
How about $15.00 shipped for the Na50 air box with right side cover to 55406?
PM me a paypal and it's done.
Kim
HEY PRESTON:DO YOU HAVE A HEADLIGHT RING? IF SO IS IT IN GOOD CONDITION,HOW MUCH? THANKS,CLYDE
Preston Timmons /
Na50 rear wheel wont work on nc50 engines cog thingy front wheel will fit on nc50 and na50s ill have to check on the gas cap they are probably not original. Two speed motor has good trans gear, needs probably crank seals not sure. 2 speed are auto and the second gear kicks in around 15 mph and runs you 30-40 depends on tunning.
Preston Timmons /
Not atm
Preston Timmons /
I sold it already for $40
Ill sell you the other left side air box for $25 shipped.
Preston Timmons /
Bump
Is the "carb with gas and oil injector" a pre auto-choke carb? I have a 1978 express with a bad carb and need a replacement.
Preston Timmons /
carb with gas and oil injector - Sold
Preston Timmons /
Na50 air box with right side cover - SOLD
Preston Timmons /
bump
Hey, I need a piston, head, ignition coil, and and a decent headlight bucket for an NA50. Name your price. I have been looking for over a month.
Still have the tank?what shape is the inside in?how much shipped to 63139?
