Re: fs: 15mm bing with special o-ring
LSLB RXb /
http://www.mcmaster.com/#6540K126
it is this type of o-ring, double seal, with the proper size when the lips are compressed it is just a hair bigger ID then 15mm and the OD fits perfectly around the intake and the back metal part of the clamp creating a solid path for air fuel mixture to pass. literally sit there and drowned that spot in carb cleaner and with no hiccups.
And according to the specs when its squished down it only .070" thick, so it wouldn't cause problems.
and it comes with a size 64-70 or 76-84 of your choice and i think 2.17 atomizer. I'll check tomorrow and give a more complete list of jet sizes i can provide. (edited)
  fs: 15mm bing with special o-ringTopic by: LSLB RXb LSLB RXb 01/16/12 11:33AM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 01/16/12 11:56AM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 01/16/12 12:03PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/16/12 12:44PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/16/12 12:48PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/17/12 08:33AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/19/12 05:53PM
  Re: fs: 15mm bing with special o-ringRe: Mikebeez Blkblk Mikebeez Blkblk 01/19/12 08:10PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/20/12 08:21AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/20/12 11:10PM
  Re: fs: 15mm bing with special o-ringRe: Kevin Carl Kevin Carl 01/21/12 12:49AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/21/12 08:39AM
  Re: fs: 15mm bing with special o-ringRe: Kevin Carl Kevin Carl 01/21/12 10:32AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/21/12 10:53AM
  Re: fs: 15mm bing with special o-ringRe: Kevin Carl Kevin Carl 01/21/12 03:17PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/22/12 02:45AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/22/12 02:15PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 01/24/12 07:26PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/07/12 11:42AM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 02/07/12 09:54PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/07/12 08:33PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/07/12 10:05PM
  Re: fs: 15mm bing with special o-ringRe: --> Jason Kluczyk Presents: Jason Kluczyk --> Jason Kluczyk Presents: Jason Kluczyk 02/08/12 02:28AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/08/12 07:43AM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/08/12 01:13PM
  Re: fs: 15mm bing with special o-ringRe: LSLB RXb LSLB RXb 02/08/12 02:49PM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 02/08/12 11:25AM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 02/08/12 01:16PM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 02/08/12 01:17PM
  Re: fs: 15mm bing with special o-ringRe: Salsa Salsa Salsa Salsa 02/08/12 01:18PM
