Puch Top Tank |||||| Moped Cafe Racer )( Custom )( //ZA//HydroFork//2Speed//HID//etc. California
Puch Pedal Moped
77 Freespirit Frame
Cafe Tank
Custom Seat
KX80 Hydro Forks with air adjustable dampening
KX80 17" wheel with disc brake setup
New brake pads
Master cylinder with brake switch
Wide chrome spoke rear wheel
18x40 gearing
ZA50 with a full rebuild, good clutches.
Roller bearing Crank
Treats CDI
Treats Reed Kit
Case matched
Malossi 4 petal reed block/reeds
Milled head
Custom 24mm intake (ready for a TM24)
Oko 21mm Carb
Velocity stack/ mesh filter
Quarter turn throttle
Treats Pipe, (cracking)
Treats (tun) Chrome Kickstand
ZA pedal shaft
Redone wiring
LED Tail light, HID headlight, LED license plate lights
Rectifier/regulator for 12v DC
12v Jel-cell battery under seat
Funzy 17x2.75 tires
New tubes
Trail Tech (may or may not come with bike depending on price)
CNC clip-ons
Bullet headlight
Aftermarket headlight brackets
New cables, knarped to length
New petcock/fuel filter/ cap
Black aluminum BMX pedals
New chains
New Sebac Shocks
More than $2000 in parts and labor
The headlight recently went out, the ballast could have failed, or something maybe wrong, someone needs to look at the light wiring. Everything else is fine. Runs fine.
Does 52 GPS'd on my ported kit, and about 48 on this stock kit on 18x40 gearing. 11,200 Rev.
1200 obo
Will supply paperwork to new owner as well as bill of sale for easy dmv registration.
19$ Lifetime Registration.
robbyasneo(at)yahoo.com
Located in Southern California
Re: Puch Top Tank |||||| Moped Cafe Racer )( Custom )( //ZA//HydroFork//2Speed//HID//etc. California
