hopefully last post about this stuff. Make an offer. I have other parts so just ask if you are looking for anything else.
noone?
No one needs fa50 parts?
What sorta shape is the rear fender in? Cracks, scuffed up?
there is a crack between the two back screws, paint and a couple of like melted spots that did not go all the way through.
also have the pipe for this and the ignition
How much for the rear shock shipped to 87701?
20shipped
thanksgiving day sale. free local pick up
how much for the pipe shipped to 63123, does it have a shield on it?
25shipped it does not have a shield.
what do u want for the controls?
I only have the left control is that ok?
bumpski
any one I want this thing out of my garage so I can work on my bug.
how much for seat 95363
22 shipped. shipping is just over $10.
How much for the kick starter shaft?
how much for the piston also??? just piston with rings ????? and the seat to 95363????
pmed
Is the choke bass stuck in the carb? It appears that way in the photos. How's the fuel cock?
I need rear fender, some rear wheel spokes, The nut that holds the shock at the top, ignition with key and matching fork lock, the screws that hold the foot pegs on (6), various other screws if you have them, the rear rack, taillight assy, and the rear blinkers. Could also use flasher unit and oil pump.
Kevin
813-508-2221
bump did not see this stuff are you guys still interested?
how much for everything in the transmission, the outer facing cover and the kickstart lever?
hey sorry for not responding sooner /... but i need choke cable with switch, seat and the carb.. does the carb work??? and do you have the rubber piece that goes to the top of the carb were the throttle cable goees and if possible the screws that hold carb .. do you have air filterbox?????? do you have ignition to start with key?? very much interested in parts make me good deal with shipping so i can get these parts off your hands!
How much for the fuel cock and carb together? Cincinnati 45209
Is the brass choke piece stuck in the carb? It looks that way in the photos
are you ready to sell that transmission yet?
need carb and choke cable seat choke switch ignition and key if have it carb screws give me good deal and will get off you and we can work out how we do money.. i have fuel cock a whole ingine and trans still all together... plus frame handle bars i want to sell in california
