Parting Out Yamaha Mj50
I have a yamaha mj50 id like to part out.. if you need sumthing just ask and ill see if i have it but its mostly complete...... pictures will be added tommorow thanks
Re: Parting Out Yamaha Mj50
Robbie meek /
looks like this one.. but worse lol. frame is junk has good motor and stuff only has 1 blinker. tell me what you need and what your willing to pay thanks
Got Pictures? Whats the scoop on the engine? How much 4 it with the rear end? thanks
Robbie meek /
pm'd you
Robbie meek /
its missing the following
3 turn signals
rear brake cable
rear fender is broke
front wheel has a dent
tires/tubes are junk
speedo/ign switch is broke
i have complete motor and trans turns over has 125lbs of compression..
good breaks, controlls missing 1 lever, carb, rear wheel (has rust)
seat has 1 small hole not bad, headlight. tailight, 1 blinker, ect make offers..
cant seem to get my bank added to paypal so i will accept postal money order or check ect. i will add confirmation number on every shippment. might be able to work sumthing out thanks
Andrew Van Zile /
Im needing a rear wheel how much do u want
How much for the front wheel?
Do you know if the headlight lens fits in a qt50? How much for your headlight?
Does the carb fit on a qt50 and how much do you want for it?
Jared Stapleton /
Need a final drive assembly. Basically, everything between the Driveshaft and the Ring gear. Got it? How much?
How much for motor/trans?
I need the bracket that runs from the motor to the rear axle on the right side. The bottom of the right rear shock attaches to it.
How much for the speedo and it's cover assembly?
I really need one and don't care if the ignition switch is broken.
PM sent.
Robbie meek /
Everything has been sold! sorry
Robbie meek /
ALL SOLD NOTHING LEFT! THIS IS FROM 2011
Need the stator!
